PriceTR24speed
- Joined
- Jan 27, 2023
- Messages
- 35
- Reaction score
- 9
- LOCATION
- Katy Texas
Plan to rework my trailer this summer so trying to figure out what the optimal setup would be to 1) properly support the boat - run a lot of bumpy dirt roads, and 2) be easy to launch and load solo especially in the wind. Boat is an Alumacraft 1542 with 15 hp Mercury
Bunks - type/covers, placement, length? Currently has 2 bunks made of 2x4's mounted vertical on edge covered by PVC Pipe. They extend just even with the transom in the back and basically cover the flat portion of bottom moving forward. They are placed approx. 12" in from outside edge of bottom. Better cover material? Any additional bottom support needed?
Front support - where, how many? Currently has 1 front support located about 1/2 way down the slope of the hull. It is a 6" wide 2x4 covered in PVC Pipe.
Guide-ons - Currently has 1 1/2" PVC pipe just slid over 1/2" rebar about 3' tall. Have materials to change to 2" PVC pipe that is fixed to bottom support (pipe will not spin) 4' tall with light mounted on top.
Typical winch point but hull shows indentions and possible cracks just below the winch ring.
It just seems to be the bare minimum and can be a pain to load on windy days etc.
Also - any better ways to strap down the back of the boat - Just using ratchet straps run over the boat now. If I ran straps from back of the boat down to trailer is it ok to attach them to the handles?
Any recommendations appreciated.
