installing a trolling motor
andy 1
I have a 14.5 lund semi v wide bottom boat. I am wanting to install a bow mount Mtoguide trolling motor. The problem is that the plate on the bow of the boat is not level and does not allow enough area for the trolling motor mounting plate. The plate on the bow is made uneven at the factory and does not offer a solid surface, I was thinking of making a plywoood plate to level the area and to attach it to the gunnel
thoughts any one?
If you can't fabricate some sort of aluminum bracket, putting a 3/4" plywood base is what I would do
several people have made what russ said, just have to look around here. i put a transom mount up front, but wish i had room for a foot controlled TM
