FishingCop
Our trolling motor seems to have developed a mind of its own. For some reason, when I have it in the 1,2,3 or 4 position, when I step on the foot control, it jumps into high (5). If I let off and step back on, it goes back into what ever position I have the dial on (1,2,3 or 4). I seem to think this is only happening when the motor is hot - meaning, after I've run it for a while. It is intermitant and no rhyme or reason that I can figure out. Sometimes it runs perfectly - sometimes it will kick up into high speed for no apparent reason. Sometimes I can hit the lever 2 or 3 times and it will run at high speed, then the next time, it runs at the speed the dial is set on??? Pretty annoying when I'm trying to sneak up on the fishes
Anyone had a simialr problem??
Motoguide, 37 lb, foot control, 5 speed (dial control for speed setting) w/ right side foot button to acctivate...
Thanks.
Joe
Thanks.
Joe
