macawman
With the flywheel off, I set the point cam follower block at the high point of the timing cam and set the point gap to .020. However, after I install the flywheel and torque it down, the point gaps are way off. So, I go to reset the points through the service holes on the top of the flywheel, but the timing cam is hidden under the center hub of the fly wheel so I can't tell where the high point on the cam is. Is there some trick to determining the high point with the flywheel installed?
