Seth
I've noticed on my boat that it turns to the right alot easier than it does to the left. If I just let go of the steering wheel, the boat will veer off to the right like a vehicle that's out of alignment.
S&MFISH said:I also believe that most engines are set up that way,so that if you are thrown from the boat,it will proceed in circles instead of just going straight into something.
Seth, check to see that you're steering cable is in good shape (probably is cause I think I remember this is a fairly new boat)....nonetheless....if it's not, it could be hanging up in one direction. Next, check the steering arms that are attached to the front of your motor and make sure they are all lubed up properly and none are bent. I don't know how they could bend, but if one was, it could cause some resistance shifting back to one side. My other thought was the same as previous advice. My jet has adjustable nuts on either side of the jet output. It will adjust the direction of the jet flow as it's thrusting water from the jet. I've adjusted mine with some success. Also, if you are running with a whale-tail....check to see that it's not bent on one side. That will cause a boat to veer to one side. I've adjusted mine with success also. Just my .02 cents worth. Let us know what you find. This is one that I haven't had to deal with and knowing how you resolve it will be good info.Seth said:Well I used the boat fishin again this past Thursday and it seems that the steering is just stiff to the left, but smooth to the right even when I'm at idle. What would make it smooth one way but not the other? My old boat wasn't like that I didn't think.
