rusmir
Ur right . It wont bother but ill try removing it . I dont think my boat will have wayer in cause its goong to be welded complietly
jirwin6985 said:No but what you did say was that since when is your foam going to get soaked for days. What i was pointing out is that if your boat is outside and you have foam on the bottom it will. Because just because you pull the drain plug doesnt mean you boat will drain all the way out. It is very common for aluminum boats to hold and inch or two of water in the drains and never drain completly out. Wich means the foam will be sitting in water. I read your post and replyed to what you said. What your forgetting is that i stated an opinion and you decided to ask me a question. I wasnt talking directly to you to begin with just giving my opinion. Im trying to save to OP from alot of work and wasted energy. within a year if it can get wet that foam will get wet and tripple in weight within the year. Ive tried using it befor and it worked for a short while befor it added about 100lbs extra to my boat.
Joe
Edit; Just read the thread again and the OP already stated its absorbing water...whats it been 3 days..really sounds like its good stuff for boat building =D> =D> :roll:
dyeguy1212 said:Nussy said:Well I emailed Dow to get the scoop on Great Stuff. There website says it's a "closed cell polyurethane foam" which is what most of the other stuff is that's used for floatation.
Here's the response " Great Stuff is used to block air infiltration into homes. The product is water resistant but the product is not water proof."
I think any foam used will eventually hold water. The stuff I cut out of my boat was the factory original and the bottom two inches were soaked.......but the guy stored it outside in the rain, with no cover and the foam directly exposed to all the elements.
I think you would be find using Great stuff in areas that won't be sitting in water. My suggestion would be to use the pink building foam between the ribs on the floor. It's easier to work with and cheaper than the foam. Then use the foam in areas above the floor like a seat, etc.
Nice detective work.. I would have guessed they'd give an answer like that.
I'd go along with what you said though.. I think spray foam should only be used in places sheet foam cant, or in areas that are sealed from water. While I've never had an issue with great stuff getting soggy etc, its probably better not to risk it.
Plus sheet foam come in varying thicknesses, making it perfect for putting under floors.
dyeguy1212 said:and most importantly, it keeps the drain grooves free
Rat said:I don't know if the pink foam board from Home Depot is Coast Guard approved, I DO know that Great Stuff is NOT approved.
jirwin6985 said:dyeguy1212 said:So take it easy with the defensive crap. Its getting old.quote]
:roll: Grow up dude..
rusmir said:Gents , were here to suggest things to each other and help each other out '! Screw the can of foam '
