PSG-1
Not a problem, glad to be of assistance. Keep us posted on what you find out.
If it's not sucking air through the intake grate, then it's got to be "pushing out"because of the nozzle being too shallow.
The first and only tme I've had it in the water it ran better with just me in the back as opposed to 2 people in the back. We had it weighted down to the point water was flowing over the transom when decelarating.
Even with just me on the back and on plane, it didn't run level like a jet boat should. The previous owner has it set up to drive from the rear, but to run level on plane the driver needs to set over the motor.
[url=https://www.tinboats.net/forum/viewtopic.php?p=318530#p318530 said:PSG-1 » 12 Jun 2013, 18:40[/url]"]You may be right about that, RivrLivn. Good call.
From the photo, it's hard to tell if the strakes are on either side of the intake scoop, or if they're right on the edges. If they're too close to the edges, it would indeed cause a massive air pocket, and cavitation. Hard to tell without being there to see it in person and lay a straight edge on those strakes to see if they miss the intake area.
[url=https://www.tinboats.net/forum/viewtopic.php?p=319162#p319162 said:PSG-1 » 17 Jun 2013, 17:28[/url]"]Now THAT is a difficult question. :? What pitch is the impeller you're using?
In my boat, I'm running a 13/19 pitch. Also had good results with a 14.5/17 pitch
Unlike a boat prop, which is the same pitch, jet boat impellers are progressive pitch, meaning the leading edge has a steeper pitch to pull the water in quickly, this is where the hole shot comes from....and then changing to a higher final pitch at the trailing edge, where the top end is generated.
Lower pitch can handle aeration/cavitation better than higher pitch. In your case, I'm thinking a 13/19, or maybe even a 12/18 would have better hookup in chop, without losing much top end.
Impros can re-pitch your prop to whatever pitch you want. Check out their website, they have a good bit of info about props.
