PSG-1
It looks cool with the OD green nozzle. Is that zinc chromate primer, or is that paint?
Anyhow, I see you ran into some of the same issues I did with cable travel and set-back. I had to add extension brackets to my pump the first time around. When I re-did the boat with the 4 stroke, I re-did a big part of the pump tunnel, and in the process, I made sure to get the set-back exactly right, now I don't have to use extensions, or modify the cables or brackets. The cable system will work either way, modified or not, as I ran mine like that for about 6 or 7 years, but I like being able to simply replace a part without having to modify it.
