blazinmoto
I have found a jetski trailer in great shape cheap but was wondering if it would fit a 1440 jon?
Any problems with using one? Thanks for the help
huntinfool said:While I would have no idea what a shop in your area would charge we have done them for $150-300( but we are a fiberglass repair shop not a welding shop). But the one's we have done were on $2000 trailers. What size is your tounge? Can you measure the inside diameter? If your inside diameter is a common size you could just buy a piece of square or rectangular tubing and slide it in and bolt it on. I would put at least 6"in and if you could get 8" that would be better. Say a 16" piece that you slide inside and use as just a coupler. Then you can bolt both pieces on.
As for you other question, Yes leaving the motor off and moving the battery would help, but it is aluminum and any bump you hit is potentially a chance to dent the bottom.
