OK, the mild winter means I'll getting an earlier start to the project. I stared long and hard at her, for a number of months, time for the work to start.
Here are the General Requirements:
This shall be a river fishing boat. Slow to medium rivers with the Susquehanna and Mohawk Rivers being the primary waterways. Also should be appropriate for flatwater upto 500 acres. Primary species, smallmouth bass, walleye, and muskie. Should fit two people comfortably, and squeeze three, on occasion. Construction should add as little weight as possible. No closed off compartments or sections to hold water. No carpet. Should be easy to wash down. Desire to have top wot, w 2 adults and gear of 25MPH. No livewell required, but should have space planing for a removable cooler style (very rare), or airated minnow bucket.
Starting Baseline:
1995 DMI 1648 Mod-V Jon Boat
Welded seams, rivited ribs
Discovery Marine Inc, Preble NY
Out of Business
Bench Seats Removed by previous owner-needs floatation foam
No dents, leaks, or rot
Good overall condition
1998 Mercury 25Hp Outboard
2 Stroke, premix, 6 gal tank
Manual and Electric Start
Short Shaft, Tiller
13P Prop
Excellent Condition
Unknown Make Trailer
Older welded tube construction
12" 4 lug wheels
Easy to launch and retreive boat
Rollers, bunks, lights, bearings to be checked/repaired
Needs repaint
Constraints:
Construction:
Limited ability to cut aluminum
No ability to bend or weld aluminum
Complete in March/April - Possible two phases (2012/2013)
Budget:
$600 Materials Only, alum, wood, screws, paint, etc
$100 Wiring, Switch Panel, terminals, sheathing
Starting Baseline:
Out of Business
Short Shaft, Tiller
13P Prop
Excellent Condition
12" 4 lug wheels
Needs repaint
Constraints:
Construction:
Budget:
