justin sumner
I have a 14' Jon boat with a 6hp motor, and am in need of replacing and extending the front deck, and adding a deck on the back of the boat.
I have been watching some youtube videos on some other peoples work they have done and was just wondering if anyone had any recommendations for me. I saw some people use angle aluminum for the supports/framing, and others just used wood, guessing wood weighs more all together, opposed to the aluminum. Problem is I am limited on skills and tools. I do not have any rivet equipment, and do not have a whole lot of experience with self tapping screws. I am not really sure if I use angle aluminum if it will hold good and sturdy, or if the screws will just wobble loose. I dont want to spend the money of rivet stuff, assuming you need power tools, and i am guessing if hand tools are an option for rivets, it is probably still costly. I figure since this is my first time doing this rivets is a bad idea because i guarantee i am going to screw things up, and i want to be able to quickly and easily make adjustments.
A few questions
What would be the thinnest plywood i should use to be able to cut down on weight? i was going to use treated wood as well
Is outdoor rated carpet good enough, or do i really need to use marine grade carpet?
Where can I get marine carpet by the square foot, if marine is necessary? The marina by me only sells carpet in huge sections and it is $300 dollars, no way I am paying that much!
The front of my boat has a metal enclosed lip on the inside of the boat about 1' or so from front to back, that is what the front of the deck is resting on. The back of the front deck is screwed into a frame the previous owner made out of aluminum and wood. Basically i am replacing the plywood, but extending the new deck to the back of my middle metal bench seat. The space between the frame he built and the bench seat is going to be storage, and i am also cutting out a storage area over the main part of the front deck. Biggest issue I have is how to secure the front of the deck to the boat, currently it is just sitting there, and I hate that because it is cutting up the trolling motor cables and the front light. He drilled holes in the front lip to run the wiring up to the front of the boat. I will cut bigger holes and protect the sharp edges, but i still want the deck secured up front. i was thinking maybe take some 2x4 pieces and screw them to the metal lip with brackets, and then just screw the deck directly to the 2x4 pieces. I just dont like the idea of having to put screws through a newly carpeted deck. Wondering if there are other methods I do not know about.
As far as the back of the boat, I am really not sure how to secure the plywood to the very back of the boat, i am covering the bench seat and using the back of the bench seat as my pivot point for the hinge for the doors that will cover the gas can and battery.
Anyways that is a lot to read, but I am sure somebody out there likes to be really helpful.
Looking for some dos and dont's and some advice on material and where to get it, and methods of framing.
If anyone has links, or videos or pictures they would like to add I could take a look.
A few questions
