Jon boat set
Amairi1
What's the best way to put seats in a 10ft Jon Boat I tire of sitting real low
Sent from my SM-N950U using Tapatalk
You can try a clamp on. One of my buddies uses a plastic lawn chair that straddles the bench. Works great.
I was looking at the clamps today and was wondering if they were any good. I was also looking at the stand
10’ boat is pretty tippy as is. The higher you get the tippier it’s gonna get.
10’ boat is pretty tippy as is. The higher you get the tip pier it’s gonna get.
Ok glad you told me that
If you go with a clamp on, make sure it has some type of brackets around the front and rear bars that hold it in place. They don't need to be that big, just something to keep it from shifting and possibly dumping you overboard.
Ok thanks for that information
Size a piece of 5/8" plywood that will give you a nice floor between the rear and middle seat.
Then mount your chair to the center of that piece of plywood..... That will put you more in the center of the boat, and will be easy to remove when you don't need it...
cover the board with carpet, and tack some of this on the bottom to keep it from moving:
https://www.walmart.com/ip/Mainstays-Hold-Plus-Rug-Gripper-Pad/20660295?wmlspartner=wlpa&selectedSellerId=0&wl13=192&adid=22222222227015440728&wl0=&wl1=g&wl2=c&wl3=80427185809&wl4=pla-177661403089&wl5=9013132&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=local&wl12=20660295&wl13=192&veh=sem
I took my screen name from on of them! I twisted to get the net in a buddies boat, the clamp on seat shifted to the side, and I went into a river backwards at night in the blink of an eye! Oh well, you could always change your screen name to overboard II! #-o :lol:
I had one secured on a boat that I owned, never had a problem with that one.
I used this seat slider bracket for the rear seat and a military ammo can for the front seat; it's also functions as the battery box.
    12.7 KB
    70.2 KB
    94.8 KB
I have my 10 ft-er set up for car-topping if needed.
Before the accident I used lawn chairs, Nice and comfy but one day while drift fishing a small river my boat mate got snagged and I foolishly attempted to swing her back upstream to save the rig. Boat mate was not ready for that, his lawn chair tipped, he tipped, the boat tipped. (hooray for flotation foam!) Other than a loss of some gear we came out OK but lesson learned about lawn chairs.
Will not help you with height but now I use Stadium Chairs similar to these https://www.walmart.com/ip/Stansport-Folding-Stadium-Seat-with-Arms/10154040
Not the most comfortable of seats but they do provide some back support and don't weigh much more than a popcorn fart.
