Jim said:Is that a good price?
bassboy1 said:I need to be shopping for it before the economy starts to turn around, but the money just isn't here yet. Even a slight increase is going to cut deep when I have to buy around 1500 pounds of 5086 sheet and plate, and 6061 extrusions.
Where was that quote from? How many other quotes have you gotten?
sparkbr said:Check these guys out. They aren't the cheapest, but they are usually reasonable if you are getting 100lbs or more. Your sheet will only be around 85lbs but you could step up to a 14' sheet to get there... What are you using te 6061 for? That is kind of an odd alloy for sheeting?
https://walden.saf.com/safcustomerweb/orderorigin/orderorigin.aspx
russ010 said:HOLY ALUMINUM BRINEMAN!
3/4" thick?? I'm still debating of how I'm going to do mine. I want to use wood because of how fast I can get it done... but I know the aluminum would work best.
I didn't seal the sheet of wood in the floor of my boat, and for that 1 week where I left it uncovered, it rained for a few days and then the sun bead down on it... now it's starting to warp.
Kurt Loup said:A couple months ago, I purchased 1/8" aluminum plate from a salvage yard for $.50/pound. Less than 100 lbs. was needed to do front and back decks, a floor and sides of a 1542.
Brine I don't want to imagine what that stuff must weigh.... :shock: #-o[/quote said:6061 alum, 36" x 96" x 3/4" would weigh 254.016 lbs
sparkbr said:What are you using te 6061 for? That is kind of an odd alloy for sheeting?
Brine said:sparkbr said:What are you using te 6061 for? That is kind of an odd alloy for sheeting?
Doesn't sound like it's odd from this description. Are you a fabricator?
6061-T6 (QQ-A-250/11d)
Alloyed with magnesium & silicon. Heat treatable to improve strength. A widely used structural alloy for light to medium strength applications. Requires much larger inside bend radii than 5052-H32, but can be formed. Combines good weldability, corrosion resistance, and strength after heat treatment.
2007NNBS said:CHECK YOUR LOCAL RECYCLE CENTER...I FOUND TONS OF IT WHERE I LIVE FOR .50 A POUND
Brine said:2007NNBS said:CHECK YOUR LOCAL RECYCLE CENTER...I FOUND TONS OF IT WHERE I LIVE FOR .50 A POUND
I'm having a hard time finding someone in North East Atlanta that will sell it. The two recycle centers near me don't sell to the public :evil:
Brine said:Thanks for the info!
To clarify....
Do you feel that 6061 is not the "right" alloy for the application?
I'm not having a problem finding it, I'm having a problem paying for it... :lol: but it sounds like it will be priced the same as the 5000's.
