Long Shaft OB on 15" Transom-Performance Questions?...
BloodStone
USSR-providence of Flint, Mi
Hello;
I currently have an opportunity to buy a "new 25hp motor" (with controls) at a really great price.
Therefore, I am contemplating putting a long shaft 1991 Mariner 25hp with controls on my modified Meyers 15' Aluminum semi-V.
The transom is roughly 15" or so. A local marine mechanic said that outside of the prop sitting 5" lower in the water, there is really not much difference in performance between a 25hp LS vs a 25hp SS on my boat (he hasn't seen the boat btw).
Is this true? Outside of really shallow water, why do I need a "mini-jacker" plate installed?
And would installing a "whale Fin" on the LS possibly help with getting up on plane better?
Thanks in advance.
Just a guess, but I'd say you're gonna lose 2-4 mph off the top end by having the prop that much lower and dealing with the extra drag.
I would find a new marine mechanic. The amount of drag caused by 5" of lower unit is huge and can be the difference between planing and not planing.
There is a place that rents 14 foot deep-v mirrorcraft boats near me. I think he bolted a 2x8 or a 2x10 on the back of the boat and caulked around it. This way he could run a long shaft on a 15 inch transom.
It will also probably fill the boat with water that will come over the transom from the motor plowing through the water that deep
