Bugpac
Any pointers, Inexpensive, easy to carry. Not looking to be a collector, Only to defend myself if the situation presents itself..
FishingCop said:If you aren't familiar with handguns, then your best bet is to stick to a revolver. I would suggest that you look at a 5 shot .38 revolver, detective's special, double action - S&W, or maybe a Taurus (cheaper). You won't have to worry about the potential problems associated with an auto - jams, stovepipes, failure to feed, keeping it clean, etc. A revolver will fire everytime you pull the trigger without fail and you don't need to worry about clearing drills, etc. Much safer and more reliable - for a novice....
Troutman3000 said:You can rent guns from most ranges as well. Then you can shoot before you buy. Once you find what you want use the GON forum swap and sell to find a great deal on a used peice. Normally 30% below retail or more. You can also trade fishing stuff for guns on that forum.
Pruitt1222 said:also ported and compensated guns are bad news with jurys.
...If its not easy to carry you probably wont.
