Hoping I'm missing something guys. My '98 evinrude 40/28 went into limp mode last 2x out (took taking it out a 2nd time to even have a clue what it was, plus first time it happened was about 100 yards from the ramp).
I took it in & the mechanic pulled weeds from the thermostat n said they were likely the culprit as they were likely not allowing it to fully open to provide full cooling at full throttle). Took it out today & it didn't go into limp mode so the overheat issue was fixed but I fear the damage may have already been done cause both my buddy & I noticed a lack of power & n increase in the amount of time to get on plane. So I thought one of 2 things: 1 somethings wrong with the pump or 2 a scored head.
Other info: no increased smoke, no unusual sounds, idled fine just didn't rev up as quick as normal.
I also noticed water coming from what appeared to be indents at the top of the pump (see video). For all I know it's always done this but wanted u guys opinions. Is the water squirting from the top of the pump normal? Could this be the cause of my loss of power? Thank you in advance guys.
