Do you have a pump at the transom for filling?
Yes, if you look at the deck pictures in the back where I have the hatches open, you can just see the pump back there, I have a hose that runs all the way up and ends at that yellow pvc pipe you see sticking out, it also has a valve on it. You can see it well in the picture of the fish.
Where is your overflow tube?
The over flow is in the top right corner in the picture, you can see a black outlet, the hose is connected on the back side and goes out one of the white outlets on the outside of the boat.
Does your bilge pump inside circulate and pump out? How do you have it set to do both because I only see the line you ran out the bottom which I would assume runs to the aerator on the opposite side.
No the line that runs out the bottom, leads to another hole in the side of the boat, if you look I have a picture of them both, one hole for the overflow, and one for the bilge. The bilge pumps it out that hole, it actually pumps faster than the other one can pump it in.
Your mod is great by the way - did it add a lot of weight by using 2x4 bracing?
Yeah I would say it did, not sure how much, but the boat is really wide, and seems very stable still yet. I am thinking about replacing all of the decking in the future with some sort of aluminum, like a diamond plate, but with carpet on it. and maybe even go with some still braces instead, not sure yet, just depends on if I see something and say wow that would make a really good deck for my boat. Its been a real PAIN in the ASS though. It was fun, dont get me wrong, but we put a lot of work into and were more than ready to get it done.
