BaitCaster
Great job. I'm interested to read more about the aeration system you installed in your livewell. I have a similar livewell in my boat and have been toying with ideas to make it more functional.
Hello. Thanks. The livewell was a very affordable and easy project. I still use the gravity feed in the livewell but I have added an aeration circulation pump, aeration head (adjustable spray) and an aerator screen on the pumps intake to filter out debris. I placed the head on one end at the top corner of the livewell and the intake at the bottom corner on the other end of the livewell. The reason that I did this was that the suction of the intake would pull the aerated water through the entire length of the livewell. I also used styrofoam insulation to help keep the water cooler inside the livewell. I placed it on the back side and underneath the livewell. I also painted the inside of the livewell with white plastic coat spray paint. This was also to help keep the temp down in the livewell. I think the total cost was around $45. It consisted of the pump, the head (with adjustable spray), the screen and some heavy duty plastic tubing and styrofoam for insulation as well as a can of white Plastic Coat spray paint. Good luck with your project! Please post pics? I would like to see them.BaitCaster said:Great job. I'm interested to read more about the aeration system you installed in your livewell. I have a similar livewell in my boat and have been toying with ideas to make it more functional.
Thank you. Also, thanks for the idea on the extension handle.free jonboat said:looks great man 8) if you want 2 save 20 or so bucks, you can make your own tiller extension. i made mine out of some pvc pipe, a sawed off hockey stick and a c-clamp. heres mine
Thank you!sgtfletcher said:Nice Job carpet look s great, like you layout
Thanks. If I can help with any questions, please feel free to ask?Sader762 said:Very good, similar to what I am working on with my 1436.
