Newbie question. First I’m happy to have found this forum, there seems to be a lot of good information and help here.
I just bought my first boat and motor (used), and I’m starting to make a list of things to do.
I picked up a 1985 Johnson 15hp electric start. Seems well taken care of and starts right up, though so far it’s just been in the tank. After laying it down I noticed that a small puddle of coffee colored oil formed under the prop/lower unit overnight. From my readings I infer that there is some water in the oil, and that there must be a seal leaking somewhere. I was going to replace the lower unit oil anyway. There looks to be two seals and an “O” ring on the prop shaft. Are these the likely culprits? How difficult are they to replace. The PO said he had recently replaced the impeller/water pump.
Thanks
Many more questions to come.
Thanks
