rabbit
After getting back from Murrells Inlet, SC, enjoying great times and hospitality (I went touring with an old salt) I needed to get a foot made for the paint roller extension handle I got.
Picked out some scrap 5/4 walnut and 3/8 BC ply, routered the "sole cove", cut tapers and rabbets with the saw then 1/4 round the top edge.:
Good strong clevis in a lathe:
Gives you:
I'll cut off where the "sole" runs wild, soak it in epoxy, first coat cut up to 20% then a coat of green.
Will get back with pix when it's finished.
When you get to Murrells make sure to check out Prosser's BBQ. Juicy. Pretty close to the best I've ever had.
Gives you:
