onthewater102
Xaero said:BAY BEAGLE said:30PCs 1/4"-20 Stainless Steel Rivet Nuts Nutsert Threaded Rivet Insert Rivnuts 1/4-20UNC
I should ask, why not aluminum?
I've had bad luck with aluminum rivnuts having the threads tear out when you try to set the rivnut. But with stainless there's no way to really put a barrier between the rivnut and the aluminum, so you're opening the door to the possibility of corrosion.
