I wanted to replace some of the foam that I took out with the center seat. I read some posts on here and it seems there are a few different schools of thought on this. Not trying to start a debate, just showing how I built my boat. I figured it wouldn't take too long and won't hurt to put some in. So far I put about a half sheet of 1.5" closed cell polystyrene in under the floor and front deck. I am planning to put the other half sheet in on the sides (whenever I build them) and maybe add some to the rear deck if I have room. A half sheet is close to or maybe a bit more than what was in the now missing center seat. I still want to add more if it will fit. I am not putting any where it will sit in water and am hoping I don't spill gas with the new motor. The old one seemed to always spit some gas out when hooking/unhooking the hose. I may just put a shutoff valve in the line so I don't have to remove the hose on the new motor to run it out of fuel.
Under the floor. The 2x2's will sit on top of the ribs so the foam won't be sitting in water (unless I get a bad hole in the boat):
Under the front casting deck. I may try to put some more in the very front of the bow, there won't be much I could store up there anyway:
Any suggestions or ideas on storing an anchor in the front? I was thinking of cutting a hole or oval in the front cubby to feed the rope through, and then just flip the mushroom anchor upside down and put it in the hole. The cubby is a little small to put a door in if I leave room for a bow mount trolling motor. Not sure if I will put a front trolling motor on or not. I have an older motorguide that I was thinking about putting on...
something like this for the anchor, hope the pic makes sense:
I looked at the electric anchors but the units would take up alot of room. They aren't cheap either! I like the anchormate units also, but they are pricey as well and require mounting space too, just not as much. I figure the current method works ok (get up, toss the anchor, tie it off) I just want a place to put the anchor where it is out of the way. The main reason I started reworking this boat is that I can't stand having my fishing gear all over the place. I want it somewhat organized and tidy. Right now when I go it is a mess of wires, rods, buckets, tackleboxes, anchor ropes...
