Mojo said:
Rat,
Thanks for the reply. OK.. First.. Those cracks are all over the bottom of the hull. They aren't localized to forward or aft.. but there are more in the rear and middle areas.
You lost me at Strake... yea... not that technically hip on the small boat lingo. There are no stringers on the interior of the boat. It's just a solid fiberglass mold as far as i can tell.
"The fairing you will need to do will be the lamination edges of the strakes biax cloth, the hull sides by the spray rail and to fill the weave of the cloth." I didn't understand what you were talking about here at all. I need some edumication on it please!
Based on those locations I would say they occurred at speed (while planing) and is either due to overpowering the hull or a weak hull, less likely but possible is overloading.
Fairing: is nothing mor than making everything glass smooth. We are familiar with smothing out of fenders during autobody repair, it is the same thing. We use a fairing compound, or make our own from Silica, to fill in the low spots on the hull; we also use it to fill in the weave on the fiberglass cloth or matt we use. Once you have applied the epoxy it will harden to the weave of the glass and be rough. Fairing fills this in so we have a glass smooth bottom and sides. More sanding...
Strakes are the "runners" on the bottom of the hull. Your hull has a Vee bow but a flat bottom, similar to a dory. On a full Vee bottom we call it the keel, but on flat bottoms we cal it/them strakes. They help stiffen the bottom of the hull and to keep it glued to the water in tight high speed turns; they also help protect the bottom when beaching as the strakes take the damage and not the bottom of the hull. My suggestion is to add two more strakes on the bottom of your hull midway between the strake you already have and the chine (where the hull bottom meets the hull sides). This will give you better performance in turns, better protection from obstructions and a much stiffer bottom so we don't have these "oil can" cracks again.
Laying the glass cloth "up to the spray rail" just means covering the bottom and up the sides to the first break in the hull. In your case it looks like you have kind of a stepped chine and I would end the glass cloth right there. It is easier to make it pretty when you end on a break then to try and feather the edges, for me anyway.
But basically you will need to smooth out (fair) any edges of the glass cloth to make nice uniform transition without bumps and bubbles and get a glass like finish on the bottom. It looks prettier and it performs better.
Realistically you can probably, with help, lay the glass one day, add the strakes the next and maybe a couple of days of fairing and sanding. Easily done in a couple of weekends with a little time after work thrown in. The epoxy curing will take the most time, and the sanding
