New River Rat
As far as I can tell, the Minn Kota Endura MAX 55 lb is the strongest thrust 12 volt troller made. Does anyone know of a 12 volt TM with more thrust pounds?
i have an older minnkota 65 lb model- not sure whats CURRENTLY made with that sort of power but i guarantee there are older models with even higher thrust. they probably just got away from doing low voltage high thrust stuff since the advent of higher voltage systems.[url=https://www.tinboats.net/forum/viewtopic.php?p=332374#p332374 said:New River Rat » 18 Oct 2013, 17:36[/url]"]As far as I can tell, the Minn Kota Endura MAX 55 lb is the strongest thrust 12 volt troller made. Does anyone know of a 12 volt TM with more thrust pounds?
[url=https://www.tinboats.net/forum/viewtopic.php?p=333661#p333661 said:krawler » Today, 00:02[/url]"]The 55lbs will push around most boats under 18 feet just fine.
[url=https://www.tinboats.net/forum/viewtopic.php?p=333589#p333589 said:New River Rat » Yesterday, 05:26[/url]"]I've ran (several) MK Endura 55 for years and in the river environment, a battery loses its draw quickly as it is moving the boat against current. I use two batteries wired parallel for my applications. This is an all day design using 12v and two batteries. If I were using a 24v system, I might get 5 hours charge out of two batteries fighting river current.
Sharpix, I can appreciate your logic, but I have experience and the good sense to know what I'm doing. I use as short of 4 ga. wire with as tight of connections as I can. Inboard charger, too. And the trolling motor is not used as a primary propulsion.
Point of my search is moot now.Just bought another MK Endura 55.
[url=https://www.tinboats.net/forum/viewtopic.php?p=333704#p333704 said:Zum » Yesterday, 15:20[/url]"]There are other 55lb thrust trolling motors and as far as I know, that's the biggest you can buy for a 12 volt system.
I own a traxxis and a power drive;55 lbs TM.
To me the power drive has more"power" (especially in reverse)but I'm pretty sure it has more to do with the prop size than the actual motor.
The prop on the PD is physically bigger...not sure about the pitch.
