motor height
Should work fine. As long as it is jumping on plane you are good. Run it loaded up with gear and people and see how it does.
Correct height set-up is the most important part. Since your there everything else tweaks it a little more. Straightening grates and filing the burrs off, keeping the impeller dressed and shimmed are the next steps to keep up with and maintain.
You will get some at extreme angles since the water doesn't have a straight shot down the hull to the intake.
