JasonLester said:Looking at it I think you could probably build it in a way you only need to anchor up there in frount above the water line. Or possibly use the bow peice to hang a support from.
As far as framing... I would think 1x1 or aluminum would do just fine weight wise. Either should be strong enough if done right...Just no pressure treat.
