- Joined
- May 15, 2010
- Messages
- 3,721
- Reaction score
- 411
- Location
- Central Florida
- LOCATION
- Lake County, Central Florida
You are having your share of issues!
There are only three usual ways to shear a key. Running in a resonance RPM range which I am guessing you are not. Not cleaning the tapers prior to placing the flywheel back on the crank (most likely culprit), or not torquing the flywheel. If either of the last two was the reason then a piston stick/rapid decel can create a key shear. Not normal or likely but it can. Lets hope it was just a key.
Now, unless you engine was far enough out of time to kick back against the starter the lock-up may be a concern.
Compression drop you found may have been the key to it.
On a light piston stick the engine cannot be turned over by the starter immediately after the stick. After a couple to a few minutes the piston cools enough to free itself from the cylinder wall and the starter can do its job better. After idling and slow running that area that stuck kind of "heals" itself to a degree and compression numbers can come back up a little.
Unless you feel like pulling that cylinder head and looking in there or pulling the intake by-pass cover and looking in there then just be aware that it may have stuck and you will need to run extra oil for a while and run easy to flush debris that will be coming off the walls and piston.
If it stuck a ring with debris it will shorten the service life of that piston/cylinder. Not trying to scare you...just educate you.
Now, let me get this straight, you still have not physically pulled the HS jets? Without pulling them and cleaning them there is absolutely no way you can tell me or fool yourself into absolutely knowing they are clean. I would rather see your engine running with a completely closed off HS jet than one that is still just dirty enough to create a lean condition. And that run may have stuck the piston. Hello?
The plug color will not change fast enough on a single WOT run to let you know the condition.
Do your part the right way and quit taking short cuts. If not then my help is done.
