[url=https://www.tinboats.net/forum/viewtopic.php?p=362659#p362659 said:
Pembroke36 » Yesterday, 19:22[/url]"]
Nice boat. How is it with all of that wood in there? I just started a 12' v as well.
It's all modular and friction fit. Designed to be held down by the gunwales and overlapping sections. There's three screws in the bow plate and that's it. Pull those three out and it all comes out one piece after another. You can sort of see what I mean in these pics:
The rear deck is also modular. A couple screws out of the "wing boxes" and it all just lifts out:
The very bottom deck just sits on the chine "kick out" and some added Al angle:
Make sure you have and access hole in the very bottom deck to use a manual bailer (IE:bucket) if needed:
Besides weight and convenience, I built it this way so that the hull and the ribs/structure was not touched. No screws, no rivets, nothing. The only alterations to the actual boat itself is the Al channels blind riveted to the seats, which has no effect ont he struture of the boat. I wanted to maintain the integrity of the structure so nothing could be touched. This is also why I worked my design around the bracing and the seating, rather than alter or remove it. My tinny sees the Atlantic ocean from time to time and I wanted it to stand up to the pounding it sometimes sees. It's not just a flatwater boat....it runs 3-4 foot lake chop (on or off plane) without fuss and 5-10 foot rollers on the Atlantic. Fair weather only though and no whitecaps in the rollers. It is only a 12 foot tinny after all....I'm also never the only boat when out on the Atlantic. We go in a group of boats.
The electrical bits are all put together with weather sealed metripack connectors so they're easy peasy to remove.
[url=https://www.tinboats.net/forum/viewtopic.php?p=362662#p362662 said:
Catfan84 » Yesterday, 19:41[/url]"]Thanks for the photo and the input great white got one question for ya though how is that deck on a12 foot boat? I was thinking about doing that but was worried that it would make the boat a little bit tippy. I did see a post where some one made pontoons for the side but some of the places I fish have allot of down trees and would probably end up just smashing them off a log jam so probably not the best idea for me
My deck is fine and stable, but my boat also seems to be wider than most tins on the forum. It's 60" in the beam and 51" at the chine. I still wouldn't stand on the rails though. I usually just sit in the front seat and fish:
Which is actually right in the middle of the boat, right over the center bench in the spot you would row.
My decking also isn't very heavy. The whole "insert" is just a tick over 60 lbs. The decking is only 3/8" plywood and a simple utility grade to keep costs down (it's covered in carpet after all). The strength comes from how I built it:
The understructure is bonded to the deck (clamped and glued) and is the real strength. I work in the aerospace industry and have a decent working knowledge of composites and keeping structures strong and light.
I didn't water seal it. I didn't want to add the weight of a gallon pail of sealer to the boat. I generally only fish when it's nice out and even when it gets wet, it goes back into a nice dry garage. I also stitched up a covers so it stays dry when traveling:
So it's pretty much dry it's whole life. If the wood rots out in 5-10, years I'll just replace it. Or I might do aluminum next time.
If you want "outriggers" and are worried about damaging them, just make them hinge-able and lock them up and down as required. I'd build your deck and try it before going to that extent though. Maybe even take your bare hull to the water and try standing around in different spots to see where the C of G is going to fall for your boat.
Cheers
