Battery for Bow mount trolling motor
davidj65
TinBoats Supporter
Owego, NY
I currently have a basic 55lb MinnKota in the stern that I use for shallow water and edges, just nosing around coves and such. Runs all day with that level of use on a group 31 Interstate 12V lead acid battery, which also powers the house stuff (lights and sonar and 12V phone charging ports). No spot lock, I use an anchor.
I'm planning on upgrading to a bow mount Terrova and use the spot lock instead of the anchor. The troller will obviously will be running a lot more than it currently does. So I am wondering, what can I expect for battery life? Do I need a couple batteries to get through a long day of messing around?
I like the idea of the LifePo batteries but don't know much about them. The lead acids have been fine for me in my very limited experience, but I'm not tied to them. Ditching some weight would be good. Can the lights and sonar also be run off a Lifepo?
I know some people say not to run sonar off the same battery as a troller, but so far I haven't had any issues with that.
I have a 55# MK with spot lock on my 16' Sylvan side console. It runs on two dedicated group 31 lead acid batteries. It can last for up to 8 hrs depending on how hard it is used. When these 6 yr old batteries give up, I will replace them with a single 140 ahm LifeP04 battery and expect to get similar or longer run times. I also have a dedicated start battery for the motor and a group 29 deep cycle for all accessories as a house battery. LifeP04 are great...but MUST be handled correctly with storage and handling.
I highly suspect that your current G31 will be fine. Try that first and check the voltage level before you put the charger on, at the end of the day. If you find it is deeply discharged, then that would indicate you want a large capacity LiFePO4. My guess is that your stearn trolling motor is fixed speed selectable, which are not as efficient as your new Terrova. So you gain a little there.
If you use or plan to go with one of the newer "Live" or forward scanning sonars, they tend to be power hungry. That could drive you to two batteries.
You didn't mention it, but if your battery is connected to the motor, it will take a special LiFePO4 that can handle the charging from it. As Airshot mentioned, there are some extra precautions using LifePO4, too.
I have a 55# Minn Kota Powerdrive on the bow of my tinnie. It is outfitted with a ProNav controller so the TM setup has all the navigation and wireless control features. I use a Group 31 size 100Ah LiFePO4 battery mounted in the center bench to power the TM, along with my H'bird Helix 7. I don't know how long the battery will power that whole setup; I've never been able to run it out of juice. When I fish the small and medium size lakes that I have nearby, I typically only use the outboard for the first run in the morning, and the recovery at the end of the day. All of the rest of the time is spent on the TM.
I crank the outboard with a separate small Group 24 lead acid.
The LiFePO4 weighs 26 pounds. The much smaller LA battery weighs nearly 40. I know a Group 29 LA battery will be pushing 70 pounds or more.
Like others, I would try the battery in hand before deciding to buy another battery. However, if I'm buying a battery for the new TM, I'd go with a LiFePO4, no questions asked. The cost of a LiFePO4 is approaching the cost of lead acid, and it's superior technology and longevity. I think the Terrova is 24V; my suggestion applies for that situation as well.
I have a pair of 100 AH TimeUSB LiFeP04 batteries for my various TM setups.
On my last trip out, I connected my Time USB 50AH battery to my M. Kota 55# Terrova because I had it around. I thought I'd swap batteries after awhile, but that battery ran all day long, mostly for spot lock, but with a few decent runs thrown in. I was impressed!
It's temptimg to use the 50AH more if it performs like that. It's much, much smaller, and seems to run the MK exactly the same as the bigger ones. It's at least as strong as my Group 29DC lead battery, which is impressive
thanks, that's my general feeling, try the current GR31 and see how it goes. I've had great luck with interstate batteries in general. The current one is a new dual use that I bought with the motor two years ago, but my boat came with a 2017 Interstate gr31 dual-use that the previous owner had used for the troller, and it still holds a charge just fine. I have a separate dedicated wallyworld starting battery, so the troller is running the minnkota and the sonar.
LA will last a long time when they are maintained well. Charge them right after each use, goes a long way. I went to LIFePO4 on the jet boat to reduce the weight and the much longer lifetime. Now, they like to be charged the day before you go. As long as they are not too low at the end of the day, just wait for next trip. Mine do not have the internal heating pads, so also can't charge when at freezing or below.
I run a 100AH Li with my terrova on a 14'. I've never run it down below 70% in a day of fishing 6-8hrs--mostly trolling at up to 2mph and spot lock but also with runs at full power. Unless you need to go days between charges or literally fish ALL day, it'll do you fine and the weight savings is great. But also no reason to buy new if the current LA is holding up.
If you do a search I posted a table a while back of current draw and speeds with the Terrova at every motor setting, if you think that info would be helpful.
