I bought a fairly cheap Stowaway Exide dual-purpose marine battery. I am hoping it will run my 34lb trolling motor for at least a couple years. I figure since it's a less expensive battery, it won't be as good, but all I need is something to get the job done. To make it last longer, I am thinking I will keep it inside when it's cold, top it off when needed, and make sure I got a good charger. I should be buying a charger from someone here soon. I don't know about topping it off though.... I hear you use distilled water, but how do I know when to top it off? Never used a lead acid battery before so it's new to me. I will probably just be buying a charger, I think it's a dual rate, but not a maintainer. Any bit of advice that should help me get the most out of my battery? Thanks
