dkonrai
new member here that has a couple of questions. bought this tinny that is pretty thrashed. ive got dents and stress cracks. i bought the boat, trailer, 74 johnson 15 hp for 400.00.
transom replacement, i have narrowed it down to 3/4 exterior ply. is it ok to run the new transom almost full span/width/length? or do i just follow the old layout. it seems odd that the original transom was in 5 pieces. wouldnt two full layers be stronger? i will be using spar varnish to protect the new wood.
i also will be having a new dog leg made too. i have some 1/4" aluminum plate that will be used.
seats will be 3/8 ply, spar varnish, covered in carpet. or i might just paint it with some bullseye primer.
leaking rivets, stress cracks. plan to drill the stress cracks and use some marine putty epoxy with a aluminum patch. now is it better to coat the rivets with gluvit? or aluminized gutter sealer? i plan on using etching primer then some rustoleum oil based marine paint to paint the inside.
here are some picts.
thanks
dino
thanks
dino
