DriftinMT09
Hello guys and gals. Brand new to the forum here, but have been checking out past threads for the last few days. My wife and I were looking for used boats up here in MN, and we found one that fit our size needs, and picked it up on Tuesday. It's a 1981 Lund S16, with a 1990 Johnson 30hp. Boat has been well used, and painted a few times over. Took it out last night for our maiden voyage in it, and we only had a few issues.
The two I am most concerned about, were that the motor while in gear, but very low RPM, would just randomly stall. I was able to restart it with a little throttle manipulation both times. Running higher off idle, it never happened. Not sure if I need to do a thorough carb clean or maybe just as simple as a new set of plugs.
The other is that after our 1-1/2 hour time on the water, there was around 1-2" of water in the back area of the boat around the fuel tank. Previous owner said he saw a very slight trickle from the bore around the drain plug, but didn't suspect it was the plug itself. As I am new to owning my own boat, and my experience with my parents boats is not really relevant (they have a pontoon, and used to have an Alumacraft Phantom), I've not much experience with open bottom riveted boats. Is there a chance I have some loose seams that are leaking?
