Thanks for all the great reference material and advice here. It's a huge help.
I'm restoring a 1956 Evinrude 5.5. I've replaced the coils, points, and condensers (Sierra parts). I've also replaced the spark plug wires and boot plug connectors. I'm getting no spark on the top cylinder and weak (seems like intermittent) spark on the bottom cylinder.
Here are some of the vitals.
. Top coil: 3.9 ohms impedance from primary (at green terminal connector) to spark plug wire (at the plug boot terminal)
. Top coil: 4.2 ohms impedance from the secondary (at black terminal connector) to spark plug wire (at the plug boot terminal)
. Top coil: continuity between primary and secondary terminal connectors
. Bottom coil: 4.7 ohms impedance from primary (at green terminal connector) to spark plug wire (at the plug boot terminal)
. Bottom coil: also 4.7 ohms impedance from the secondary (at black terminal connector) to spark plug wire (at the plug boot terminal)
. Bottom coil: continuity between primary and secondary terminal connectors
. Measurements taken with coils sitting on armature plate but all wires disconnected from ground, points, etc.
. No spark on either cylinder wire when pulling starter rope on old plugs with terminals bent open about 1/4" and touching ground
. No spark on top cylinder wire when pulling starter rope using ignition spark tester (about 3/16" gap)
. Weak spark on bottom cylinder using ignition wire tester at 3/16"... yellow or white but not blue, and only seems to spark about half the time.
. New wire stamped "7mm COPPER CONDUCTOR CABLE", Part BKD MW11 from O'Reilly's. Looks exactly like what's sold on West Marine and eBay as Sierra part number 18-5226.
. New spark plug boot terminals, also BKD brand from O'Reilly's.
. New points gapped at .020" and adjusted to open at the beginning of the range (points lose continuity when flywheel notch reaches the first mark on the plate).
Questions:
. Is it possible for flywheel magnets to go weak?
. How often are new condensers bad? I haven't seen that there's a way to test these with tools the average person has access to... Is that correct?
. Would it matter if I haven't put on the rubber boot protectors (on top of the boot plug terminals)?
. Is it possible the ignition wire isn't the right kind?
. Did I wire it wrong? At this point I've taken everything apart 4 or 5 times and have a printed photo for reference, but there's always the chance.... Here is a photo.
. What else can be tested?
. What should be re-tested?
Thanks in advance,
Dean
Questions:
Thanks in advance,
Dean
