I finally have my cable run for my front trolling motor and now I am moving on to some lights.
I see most everyone installs switches for the different devices.
I was looking at an atwood base for a removable bow light that looks like good quality with a drain and stainless cap.
Would it be ok to put the fuse at the battery and wire it direct to the base without a switch?
That way when you wanted the light you just plugged it in. I don't have a console to place the switches on and this seemed like it would be a "cleaner" install.
Does anyone do it this way or is it not doable for some electrician reason?
