baptistpreach
Looking good! Keep it up. Carpetting is like painting, it brings a very rewarding feeling when you're done
grizzly said:i had the same issue, the carpet will just squish down and not cause a problem. i had rivets on the bench seats that stopped it from seating down, so i dabbed some crayon on top of the rivets and then carefully pressed the plywood on top, this gave me exact locations to drill a shallow relief hole with a forstner bit on the bottom of deck.
grizzly said:if you don't mind pulling out your staples, you could pull it back from the edges and tack on a small strip of solid wood ripped down to the size you need, then roll carpet back down and you would never know it was there. i had to do that on one side of my bow deck where my angle was not quite right, came out seamless and i'm the only one that knows its there, and i'm sure i'll forget soon enough.
