MrGiggles said:
If you're just charging one battery, not really. It's easy enough to rig up a quick connect harness. Get a digital charger that's at least 4 amps and run with it.
It's when you're charging 2 or more that they become worth it IMO. Each battery gets topped up and charged equally, without the hassle of swapping a charger around.
Battery chargers as a whole seem to be unreliable nowadays. I've had a Promariner for almost three years now and it's been fine. I only leave it plugged in long enough to charge fully and then unplug it. I think leaving them plugged in is a mistake.
I have a Minn Kota precision charger for the TM battery. I usually plug it in as soon as I get back from the lake and leave it. Minn Kota says I can leave the charger plugged in. Says it will stop charging when the battery is full then go into some kind of monitoring mode. I sure paid enough for the thing, so I hope they are right about this.
For the starter motor I have a small Noco. I usually plug it in the day before I'm heading out. I just want to make sure I have enough juice to turn the motor over a couple times.
The Minn Kota charger weighs something like 4 - 5 pounds. The small Noco weighs next to nothing.
