daschmetterling
Ok, like so many of you, I have been following all these builds and have been getting inspired for one of my own. What a great community of people on this site! So here is mine, or I should say "ours", since this project belongs to me and 2 other fishing buddies. We have been looking for a 16' jon boat for several years, and would ideally have a jet for running rivers to fish. But, with our budget, we ended up with this v hull, 16' sea hawk, and a 2003 50 hp Johnson prop. We have a lot of ideas for the boat, and it is just going to be set up as a serious fishing rig, with a center console and not much else to make room for trotline gear, rods, and big fish (hopefully).
Today was our first day on the build, we put 2 new tires on the trailer, replaced seals and bearings, made some adustments to the winch and bow stop, and set about to remove the transom. Since we are starting from nearly scratch on the boat, we figured now was the time to replace the one piece of wood. I got out all 30 or so rusted screws and bolts, remived the splash deck drain cylinder, remived a half dozen rivets, scraped off the old caulk, and even cut back some aluminum trim on the gunwale to easily get the transom out and in easily (this will be covered by end caps, so you won't see my cuts).
That all went pretty smoothly, but we still can't get the transom out!
That is what lead me to write a post- I need your advice! Any tricks?
We actually attached the transom to a chain connected to a winch on the ceiling, and ended up lifting the boat off the trailer (with me in it), and hammering and prying did nothing to budge it!
The only thing I can think is that the plywood transom is so waterlogged and swollen that the ends on the side are wedged.
uploadfromtaptalk1446333983443.jpg30.6 KB
uploadfromtaptalk1446334022932.jpg37.3 KB
uploadfromtaptalk1446334108185.jpg78.4 KB
uploadfromtaptalk1446334204245.jpg53.9 KB
uploadfromtaptalk1446334275044.jpg71.3 KB
uploadfromtaptalk1446334348500.jpg39.1 KB
uploadfromtaptalk1446334593248.jpg54.2 KB
