[url=https://www.tinboats.net/forum/viewtopic.php?p=352277#p352277 said:jigngrub » Today, 11:33[/url]"]That would be mission impossible. Gluvit is designed to be a very thin, runny, drippy product to be used on the inside of the hull with the boat in the upright position. It'd designed to run into all of the minute cracks and crevices.
Even with the boat upside down and applying gluvit to the exterior isn't a good application. It just wants to run over the top and run/drip down without really penetrating anything... and then it has to be painted to prevent UV breakdown.
The only way you can permanently fix leaks in an aluminum boat from the outside is to replace rivets and apply riveted on patches to cracks and such. Everything else needs to be addressed from the inside of the hull.
This is an easy way to replace leaking rivets:
https://www.youtube.com/watch?v=L0MA1-5NXjs&feature=related
[url=https://www.tinboats.net/forum/viewtopic.php?p=352547#p352547 said:jigngrub » 16 May 2014, 18:23[/url]"]I would not apply ANYTHING to the leak until it was fixed to my satisfaction!!!... and again, if you apply gluvit you have to paint over it to protect it from U breakdown.
WD, I'd say that you're either a much better man than I am or you're a bigger glutton for punishment... or, I'm a much bigger a-hole than you are. Still having a leak in that boat after 2 attempts would be the breaking point for me, fixing a leaky aluminum boat isn't rocket science or brain surgery... it's not even rocket surgery or brain science! Testing to see if you have the leak stopped is easy, you put water in the hull and wait for a little while and check to see if there's water on the outside or ground.
I'm not trying to make you mad or whizz you off, it's just that I have a huge problem with inept people working on my boat, mainly because I've been ripped off twice by supposed professionals that didn't fix my boat the way it was supposed to be fixed. There's still one shop in town here where I would love (and have contemplated) going down there with a baseball bat and breaking everyones legs... of course I'm not going to do it, but I do think about it.
I sympathize with you and if you lived closer I'd fix your leak(s) for free, you just supply the materials.
I hope your problem is fixed this time and you go out and catch a bunch of fish to celebrate... and if you do, post us some pics of celebratory fish please.
