Polar Kraft 1448 build
Finished the livewell today. It’s 17 1/2” diameter and the same height as the the deck. I’m installing a LED light in it and a recirculating pump. It has an overflow and a bottom drain. I’ll rivet it to the floor of the boat after I paint everything.
    3 MB
    2.3 MB
A couple more pics.
    1.6 MB
    870.6 KB
Slowly but surely this build is coming together. Hope to be finished by spring.
    653.6 KB
    2.3 MB
Picked up my new trolling motor at Cabela’s today. I needed to fab a riser to get it to the proper elevation, in my case 3 1/4” was needed. I used scrap from my aluminum deck, 1/8” thick. TIG welded it together then ground it down so it will paint nicely.
    3.1 MB
    2.2 MB
Couple more pics
    2.6 MB
    3 MB
The things I would do if I had access to a tig.... You've done some nice work so far, lots of interesting and original details. Looking forward to watching this one through to the end.
Thanks for the “atta boys”! Can’t wait to post the final pic of the boat in the river for you all!
Fabbed a “dashboard”. Will hold the fish finder, navigation lights and rod holder bases. The wiring will be easy to access from a removable panel that will screw to the front.
    3.1 MB
    2.8 MB
    2.7 MB
Drilled holes from the battery box in the center seat (was the factory livewell). I welded a 3/8 round rod to a 15/16” spade bit to easily chew through the styrofoam. I did this on the front bench; trolling motor wires, lights and fish finder. And the rear bench for; bilge pump, livewell pump and lights. I used a piece of flexible 3/4 bilge hose attached to the shop vac to chase the holes to get all the tiny pieces of styrofoam out.
    3.1 MB
    1.2 MB
    2.6 MB
    1.9 MB
I bought a Weiler cupped wire brush. It’s fantastic. I used it to take the paint off the aluminum tube rails. I figured the rails are going to get beaten up against the dock so I won’t paint them. This wire brush also made quick work of the Polar Kraft decals.
If you use one of these, besides safety glasses wear a full face shield. The wires will snap off and get you! A few years ago I had one from a a different wheel go through my lip.
    2.2 MB
    2.4 MB
    3.2 MB
    1.9 MB
A side note, if you use this wire wheel, it’s heavy. It broke a very used 15 year old Harbor Freight grinder in 20 minutes. I put it on another HF grinder and it survived. Took about 1 and a half hours to remove all the paint from the rails.
Next up; running wires and mounting the battery charger under the front deck.
    3.4 MB
Even if I had a TIG I wouldn't be able to do that! Haha
Agree, three is some remarkable stuff happening with this build.
Put the deck on for a minute before I fasten the totes to the deck supports. Looks almost fishable.
    2.4 MB
Got the boat about 95% sanded and ready for paint. Extended the power cable on the new trolling motor. Ran wiring under the front deck. I hope to get a little painting finished this weekend.
    1.8 MB
