gogittum
On my "Jinxed" thread, I mentioned that a rivet had popped under the rear seat and was letting a fountain of water into my 16 ft Starcraft boat.
I crawled under there a bit ago with a flashlight and was astonished. "A" rivet ?? One ?? Count 'em by the dozen. The heads are missing off at least 20 and I'm sure the actual count is much higher than that. Some show shiny metal, which I'd think means they are recent fails. Others - many others - are the same color as the surrounding metal, so prob'ly long ago fails. Most don't leak.....figure that.
I've noticed that the floor under my left foot is oil canning now when I put weight there. It didn't do that when 1st got it.
When I started refurbing the boat after purchase, I pulled the center seat out to add the folding grab bar. At that time, I noticed that the aluminum gussets that hold the seat to the hull had several missing rivets as well. I re-installed the seats and repaired the rivets with stainless steel core aluminum blind rivets that don't leak when set.
Uh....I did say "jinxed' earlier ?? Seems like the problems are never-ending.
Fine, but to do this right I'm going to hafta pull the motor and flip the boat over. Working with limited room underneath with frame rails, bunks, etc., in the way just isn't feasible. Then, too, I'll need the 18" heavy duty rivet puller. The small hand grip one simply isn't up to the task.
Is this a common thing with older aluminum boats ?? Mine is a 1996 model Starcraft Seafarer. No idea of the amount or type of use it's had, but overall it's in very good shape. Not scraped up or battered at all.
