thill
I think you will be glad you did, but report back as to how it worked for you.
I started repairing my boat last week and completed 2 of the 6 patches I need to make. It's not going so well, I have a few pictures I'd like to upload but the site isn't allowing me to upload them. It says "pic is too big" even after I compress the pics to under 1mb.
There's one that is accessible from the inside but the rest are either under the bench or under the floor and I'd have to pull the floor out. The 1/4 inch closed end rivets I found are aluminum however the mandrel is steel and I'm wondering if that will cause corrosion issues from the dissimilar metals. (I boat in saltwater) I'm also installing a zinc anode on the transom in this off season to mitigate corrosion.Use solid rivets, if you can get to the both sides. They are inexpensive and are very strong and durable.
The repair worked well, I'm going to test the boat in the river tomorrow when the 5200 dries. Thanks for your advice!I've done them with steel mandrels. Just put a smear of sealant in and over the hole, and they should be fine.
