That is the same machine we have here. Currently, we only have the aluminum wire feed accessories, but a spool gun is coming shortly, as I would much prefer that. I have aspirations to build this before I graduate (I am 15 now). I have been giving some serious thought to modifying the plan to allow for a motor setback bracket, and full height transom, and possibly thinking about changing the deadrise from 12 degrees to 16.sparkbr said:Thank you. Yes, it is a Lincoln 175HD with a spool gun. Lincoln says that you cannot run a spool gun on this machine, but you can with minor modification. I built this one for my own personal use but would like to be building them as a side job. In March I am ordering aluminum to build an 18' with a 60" floor to sell. More to test the market a bit and to get another boat out there with my name on it.
Brad
bassboy1 said:How well does that jet push you? I have been looking into a jet for the Etowah below the little spillover dam, and above the main lake. It is a pretty rough river, so most guys that run it ('specially the lower end) put the UHMW plastic on the bottom of the hull, and exceed the max hp to get out of the hole quicker.
What kind of hole shot you have with that?
