Zum
Sorry about your boat.
It is good for people to hear personnal experiences.
Glad you chimed in.
Glad you chimed in.
[url=https://www.tinboats.net/forum/viewtopic.php?p=346100#p346100 said:samiam81289 » Yesterday, 16:14[/url]"]hey guys i have a 20 ft cobia and i just tore the old floor out and i cant really afford to fiberglass i got pressure treated wood how can i am carpeting over it how can i seal the wood without fiber guys
ty guys a bunch in advance
jigngrub said:[url=https://www.tinboats.net/forum/viewtopic.php?p=346100#p346100 said:samiam81289 » Yesterday, 16:14[/url]"]hey guys i have a 20 ft cobia and i just tore the old floor out and i cant really afford to fiberglass i got pressure treated wood how can i am carpeting over it how can i seal the wood without fiber guys
If you can't afford to rebuild your boat correctly, you probably can't afford to own a boat... but then there are the people that can't afford to rebuild their boat the right way, but when it comes time to fill it up with gas and oil to run it around on the water money is no object.
... and what's a guy with a fiberglass boat doing asking for advice on a tin boat site???
"Glassing" a deck in on a fiberglass boat is an important structural component of a fiberglass boat, a glassed in deck on a fiberglass boat is a diaphragm that holds the boat together like the solar plexus (diaphragm) in the human body. The glassed in deck holds the sides of the hull in place and keeps the relatively weak fiberglass from flexing too much. A glassed in deck on a fiberglass boat also seals off and waterproofs the below deck bilge area preventing water intrusion on the structural stringers and transom which are the backbone of the boat and transom.
If you can't afford to fix/repair your boat correctly you should sell it or haul it to the dump because you probably can't even afford gas and oil to run it.
If you don't know what you're talking about, just don't post. The deck isn't glassed to the Hull, its part of the cap which is either screwed or riveted to the Hull under the rub rail. It waterproofs nothing, as a properly laid up glass job is waterproofed by the resin used.
[url=https://www.tinboats.net/forum/viewtopic.php?p=346248#p346248 said:muskiemike12 » Today, 15:28[/url]"]Pretty harsh there jigngrub! So what are you saying if I can't afford to put gas in my truck? :roll:
[url=https://www.tinboats.net/forum/viewtopic.php?p=346245#p346245 said:jigngrub » 25 Mar 2014, 13:44[/url]"]
Practice what you preach!
If the deck isn't glassed to the hull or glassed to the cap (tub style), it's still part of the boats structure and the hull will still flex, flop, and flap if everything isn't tied in like it was designed to be... have you got a clue yet?
Typical polyester fiberglass layup resin is worthless with fiberglass cloth or matt, it's weak and brittle and will flake and crumbles to dust without reinforcement of fiberglass... maybe this is another clue for you? :roll:
[url=https://www.tinboats.net/forum/viewtopic.php?p=346245#p346245 said:jigngrub » 25 Mar 2014, 13:44[/url]"]Just throwing a plywood deck down in a fiberglass boat without glassing it in to the hull or cap (it depends on the design) is a slovenly build that will cause major problems sooner and later.
