ITGuy
Ok...I read tons of posts and know I need a long shaft for my 20" transom. I picked up a older Johnson 10 hp that didn't seem to be a 15" or 20" shaft. It was kind of in between when I measured it at a bit over 18". Now my question is will this work on my boat with the 20" transom? I placed it on there and it looks to be within about an inch from the bottom of the transom. Also, when looking closely at the water intake at the bottom of the engine just above the rear part of the prop looks to be at the same height or just under the transom. I took some pics and was wondering what you guys think. Will this be too close? I did read that around an inch or so close would be fine, but being this is my first boat I would like opinions.
