bobmwsc
Motor is a 1987 Johnson BJ4RCUD 4hp
I was hoping that all I needed to do to get ready for getting on the water was swap out the plugs and call it a day. I was wrong. The plug swap was fine and I was glad they had the plugs at Walmart for just a few dollars a piece. I snapped them out, put some new fuel in the tank and it wouldn't start. I figured, and was correct, the carb was all gummed up. I took the motor apart, which is a huge pain, and got the carb out. I was looking online for what to clean it with and found that you can soak the entire assembly in Pinesol without having to worry about rubber or plastics degrading from the carb cleaner. The carb came out very clean and everything was clear. The attached photo is the only one I remembered to take after I cleaned it with the Pinesol.
Reinstalled and still no good. I had spark so I figured maybe a fuel line was clogged. Found that one of the lines had pretty much collapsed so I got some replacement fuel line. Still wouldn't start and now I figured I clogged the carb back up with gunk from the fuel line [emoji849]. Disassembled again and brought it to work and tossed it in the ultrasonic cleaner. Brought it home and reinstalled. Still nothing. I fired a shot of starter fluid in and I was getting it to sputter and finally got it to fire up.
Here are the questions...
Warm start it fires up no problem but I can't get it to fire on a cold start without a spray of starter fluid. Any ideas? Maybe fuel / oil ratio? Cover states 100:1 but I've read that it was changed and I need to use 50:1 so that's what I've been doing.
Any recommendations on a new starter handle? With the repetitive pulling when it wouldn't start I was ripping my fingers apart. Is a full grip snowblower handle okay?
Along those same lines I figure I should replace the starter rope though I'm not sure what size to replace it with.
This motor doesn't "pee" like other outboards (probably due in part that the fuel tank is mounted on the shaft out over the water). Instead the water is supposed to weep out with the exhaust. How much water am I supposed to see coming out though? I do see it dribble out but I'm not sure if it's enough. Time for a new impeller? Are they tough to swap out?
I'm hoping to get it out on the water when soon to make sure the motor stays running under load but with the rain in the forecast that may not be until mid May.
Sent from my moto g(6) using Tapatalk
