wmk0002
I'm working on fixing up an old 1990 Yamaha 25 that I've posted a little about on the motors forum. I have determined that this thing will absolutely need new battery cables if I get the motor fixed up to that point that it's worth the time/money. In the meantime I figured I'd decide what I am going to get for when the time comes.
First off, I went to a parts site and found the OEM Yamaha cables and they are $100 - so that's a big no from me dawg lol. Now, I do like the factory cables... the ones on my new F25 are flexible, long, and duplexed into a single line that fits nicely through the factory grommet in the lower cowling. I really would like to find some cables that came duplexed like that and preferably were both black. I'm not entirely sure what gauge the oem cables are but the starter is marked with '434' on the side which I assume is watts. If that's correct then it would pull 30 something amps at 12V meaning for a total run of <20' that 8 awg would be ok. Any ideas on where to find the duplex cables like factory? If I cant find that and have to go with a pair of single cables, what would be a good option for a looming for two cables of that size?
And lastly, depending on how I use this motor, I may not even use the electric start. Any issues with adding a quick disconnect to the cables near where they exit the cowling? I thought it may be nice to use one of those flat Anderson connectors. Seems like it would help tidy a small boat up when not using them and help keep them in good shape.
