MrGiggles
I recently purchased a 79 Alumacraft F7. The hull is solid but there are a few things that need attention, a broken bow eye being one of them.
Is there a replacement eye available that will fit?
I guess the other option is to grind off whats the left of the eye until it's flat, and drill a hole all the way through the center of it then install a universal bolt style eye. I might be able to make a V-shaped block to install on the inside to prevent it from tearing through.
The boat is not heavy in the slightest.
