- Joined
- Aug 1, 2023
- Messages
- 48
- Reaction score
- 28
- LOCATION
- Owego, NY
Started to do a DC install, pulled the deck and the bottoms of the plywood were just laying on wet foam. Some much worse than others, but all of it is wet to some degree. Mercifully, most of the marine plywood(at least that's what the label says) is fine. A lot of recent surface mold, and superficial rot around the edges that's probably been happening for a while. I'm the second owner, and I think the first owner kept in in a berth on a private lake in PA all summer, so it saw a lot of rain.
The foam installation by Alumacraft really doesn't seem so well thought out. I know nothing about this but my own common sense, but it seems that foam that absorbs water is a stupid design decision. And why they would enclose the foam in the pods in a plastic bag, no idea. Just filled with water and sat there. The foam on the floor is installed in all the framing crevices and drain points, so when water seeped between the gunwales and the edges of the floor, it had no way to drain, just seeped in-between the bottom of the floor and the foam and just sat there. Ticking time bomb
I found this by accident and if I had more experience, I probably would have known to check it as soon as I bought it last year. It is not a big deal, major pain to remove the foam but it will save the floor and I'm glad I caught it when I did.
I'm planning on replacing the soaked foam with blueboard wall foam insulation, leaving the drain channels open. I have heard that the poured in foam between the ribs provides hull rigidity. How critical is that? The floor is screwed into the ribs pretty thoroughly.
Thanks for the feedback.
