Help me choose a 22’ aluminum bay boat
CRB357
TinBoats Supporter
Broussard, LA
Looking to go from an 18’ to a 22ft. I fish mostly Louisiana Gulf Coast inshore marshes for Red fish in very shallow like 12”-18” and bays for Spec trout. Also go to Toledo Bend for bass and booze cruising with friends and family. Storage for boat is no longer an issue.
Right now with the 18’ I have to pick my days when the wind isn’t above 12 mph. Bays get too rough and the wind blows the little 18’ around in the marsh. Also, it’s a 2 person max fishing boat size/space wise.
Aluminum is the only way for me. Too many oyster reefs and other stuff. I prefer the light weight and ease of care. So not interested in glass boats.
Not looking for a “flats” boat or anything. Just a regular bay boat that can handle rough water with 4 people and fish in 15” of water.
How shallow can a boat like a 22ft Express H22 or similar type of boat go? People are telling me they can float in 14”.🤷‍♂️
Floating in 14" and running in 14" are very different. add at least another 12" on to that unless you run a JET, even then I'd want to add 6" to be safe. IDK what kind of bottoms you fish, but if firm enough you can always get out and push a light boat as long as you've got some water under you.
I’m more concerned about bigger boats floating in shallow water. I’ll narrow it down once I know which boats will actually do what I need them to do.
I can't help with the draft of boats, but I would definitely recommend getting eyes on all potential boats that you're interested in. The build quality and fit/finish may choose for you. I just picked up a new Prodrive boat (not the same I know) but I looked at several other manufactures and the build quality was night and day different. I wasn't too impressed with the Excel boats. I checked out an Avid while that the dealer had on the lot and it was quite a bit nicer. Much more solid and quieter, even down to the weld quality.
I guess what I need to know is when a manufacturer says 14” draft, what is the real world number? I’m assuming any specifications are “dry” with no gear, fuel, etc in the boat. I want to know if anyone has a 22ft+ aluminum and if they can fish in shallow water.
Aluminum Ranger RB 200 might fit your requirements
