I've talked about my 16 ft Starcraft Seafarer V hull several times on here. Hard to picture a more versatile or useful boat and is perfect for my needs....and it's riveted. I have learned.
When I bought it, looked it over and it was almost pristine - paint wasn't even worn off the floor, so I bought it - $1,000 on a trailer and with a '83 Johnson 15 hp. Don't remember offhand, but think it's a '96 model. It's a light boat - I think 276# bare hull, but the little 15 drove it to 22 mph. Gauge of metal is quite heavy and the boat is stiff.
It's a big boat for its' size - 16 ft LOA, with 63" beam (measured) and 20" freeboard. (measured) I love that deep freeboard. I won't look for trouble, but if I do get caught out in a thunderboomer, I firmly believe that boat will bring me thru it.
Look For: when I put it in the water, it had several oozing leaks. I run 2 bilge pumps for backup - try bailing a tiller boat while running at speed one time. Then, 9 miles out in the bay, I suddenly got a fountain of water from a rivet, so came on home.
Crawled under it and found that a rivet had completely failed and I had a 5/32" hole. OK, I'm a great believer in sealed end pop rivets with steel shanks, so coated one with 5200 and stuck it in there. Those things are a flyin' bitch to pop and the little sheet metal pullers don't work for beans.
HF sells a really nice 17" 2 handed heavy duty tool that makes it easy....and less than $20. It even has a little plastic jar to catch the popped ends. Buy one.
Now, the bitter bit: while under there I noticed that many of the rivet heads were corroded away and just the shank showing. "Apparently" someone had left it sitting on a saltwater beach for a long time. I pulled it off the trailer and turned it over.....and my stomach turned over. Damage was erratic. There'd be 2 or 3 good rivets, then a dozen bad ones. Almost all in the rear 1/3 of the hull, but some as far as 1/2 way. Well, I had it to do, sooo......
When the smoke cleared and I was satisfied, I'd replaced 170 rivets. Lesson learned - it's difficult to exactly drill a rivet out, even using a smaller, very sharp new drill bit as a pilot. I drilled them out to 3/16" and was very pleased with the result. COAT EACH RIVET THOROUGHLY WITH 5200.
Put it in the water and I'd missed installing rivets in a couple of places I'd drilled out old ones. My bad. Took care of that problem and still had some oozing. I put about 8" of water inside the hull after blocking the transom to support the weight on the trailer and found where several rivets hadn't sealed properly - maybe didn't get the 5200 evenly or something, so smeared some over them - on the outside - and let them dry. Drained the water.
Next time I put it in the water, it was bone dry....uh....almost. The drain plug sits 1/2" above the bottom and there was some residual rain water in there. After a couple of hours of putzing around in the river at various speeds and beaching it a couple of times, there had been no additional leakage. Bueno.
The boat looked pristine on the trailer, so didn't think to crawl underneath. After all said and done, I still think it was a good deal for a very good boat and the extra riveting only took a day. I'd do it again.
